Re: Vinyl Liner Wrinkles
Hi and welcome to the forum. I moved the thread here which is more appropriate. Yes, people have used a plumbers plunger to dewrinkle but as I remember they do this with just a little water in the pool. Enough to prevent liner damage, maybe a foot. When you figure that with a foot of water the pressure on the liner is about 0.43 pounds per square inch, you may be able to move it. A few feet, you're over 1 psi so I don't think you'll move it. I got this from the weight of water being 62.4 pounds per cubic foot and 144 square inches in a square foot. 62.4 / 144 = .43 psi per foot of depth.
Others will chime in with ideas.
