Hi, Bree,
What do you mean by "and our bathing suits show it too"? Are you testing your CYA at 20, and if so, how? Most of the tube/reagent tests don't measure below 30. Also, what do you use for your chlorine source?
If you'll give us a set of test results, done by drop testing instead of strips, for free chlorine, combined chlorine and/or total chlorine, pH, alk, and CYA, it will help us get a better idea of what's going on in your pool and how to fix it.
Brown/tan deposits that settle on the bottom of the pool could be some sort of algae, if you've not kept your chlorine up or if you've let your CYA get out of hand, but also could be dirt/pollen/dust. Is it growing on the sides of the pool, or just the bottom? Is it collecting in seams, or is it spread out in patches? When you brush it up, does it settle back down in the same places or different places? Is there a slimy feel to the liner? Have you shocked the pool lately, if so how high and using what chlorine source? Have you had any green algae recently?
Also, if you can swim down and pinch some of it, it will help if you can tell us if it's gritty or slimy feeling.
