Thread: Coping / Tile issues
    Sep 2010
    Default Re: Coping / Tile issues
    Ben,
    Thanks for the detailed explanation and description.
    2 questions then:
    1] After removing the coping and in the process of resetting it in place, would it be feasible to artificially widen the expansion joint by not quite placing the coping back in the original position but rather say 1/4- 3/8" more so in toward the pool and away from the deck? [yes it make appear a bit off overhanging the tile but if it can help eliminate the problem from reoccurring..]
    2] Would you know if there is a specific type of mortar used for resetting the coping?
    Thanks again for all your help
    Rob
    1) Yes, it's possible that would work. But it's not likely. What's more likely is that the deck is impinging on the concrete mess UNDER the coping, instead of the coping itself. However, you can do whatever isolates the coping and bond beam from the movement of the deck.
    2) I don't know. Probably any mortar that's mixed to be relatively impervious to water would be OK. (Mortar that's highly absorbent, due to low cement or high water content, is likely to suffer from freezing, if you are in a area that's (a) wet and (b) cold in winter.
    PoolDoc
