Results 1 to 3 of 3
Thread: High TA
    Aug 2010
    Central PA
    Question High TA
    I have a 24' AG vinyl pool. My TA is testing at 260 and from what I'm reading that's extremely high (it just hit me, does high FC affect TA test? 18.5 ppm). Getting ready to close it up real soon. Is it important to bring that down first? PH is 7.8
    Default Re: High TA
    The TA is high, but if you don't have high calcium levels or a SWCG, and if your pH is stable (yours is at the upper end of the "normal" range) then I wouldn't worry too much about it for now. If you have high calcium levels, then the higher TA can cause milky water problems when the calcium precipitates out of it, and if you have a SWCG, it can contribute to scaling, but if you have neither of those then it shouldn't affect your water that much, other than making your pH harder to adjust.
    If you just want to bring it down, the steps are outlined here http://www.poolforum.com/pf2/showthread.php?t=191.
    However, if you've not had problems all summer, and are closing it down soon, I think I would just leave it and adjust it next year when you open.
    Default Re: High TA
    I would agree with Jan. By the time you open in the spring things could have changed a great deal and it won't affect algae growth over the winter anyway.
    Normally, we MIGHT (emphasis on "might") worry about scaling but your winterization will have the water away from any metal so that won't be a problem either. Save the acid and effort for the spring. Besides, being a little high on the pH at closing isn't a bad thing as acid rain tends to lower pH over the winter anyway.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 01:09 PM
