Thread: Whisperflow pump problem
    Honesdale PA
    Default Re: Whisperflow pump problem
    Before you go pulling it apart check this thread:
    http://www.poolforum.com/pf2/showthread.php?t=4800
    There really are no dead spots in motors like this so I'm thinking it is the starter switch contacts. The starting capacitors usually fail open or shorted and don't usually fix themselves, but I guess it is possible, but unlikely, for it to go intermittent. I'd start with the contacts. It is something that is easy to try. Would be nice if you could pull the cover to expose the contacts and start cycling power to see if you can get it to not start, then tap the contacts.
    Hope it is something simple.
    mas985's Avatar
    Pleasanton, CA
    From what I understand, the Whisperflo uses a permanent split capacitor motor which means it doesn't have contacts nor a start capacitor.
    However, if the bearings are going bad, it could explain the periodic stalls. One way to check is the next time it doesn't start tap the motor with a two by four and see if it starts.
    Mark
    Honesdale PA
    Very interesting Mark. Thanks, I learned something. The thing still has a capacitor but is not called 'starting' since it is always in the circuit. From what I read about this configuration is you don't have the high starting torque or high starting current of the switched configuration. Guess that doesn't matter with a pool pump though. I'm wondering if it comes up to speed relatively slowly and thus the pressure spike typically seen on startup is gone? Less stress on the system then.
    mas985's Avatar
    Pleasanton, CA
    You are right about the starting torque being low at start. In a centrifugal pump, the required torque is proportional to the square of the RPM of the impeller (HP is proportional to the cube of RPM). So at start it is zero and climbs as the motor spins up so it is a perfectly fine design for a pool pump. So a PSC motor pump will start just as quickly as any other motor, at least what you can notice.
    Also, most high efficiency motors are either PSC or CSCR (capacitor start, capacitor run). Both keep a capacitor in the starter winding to minimize the EMF losses and improve efficiency. The CSCR motor has more starting torque which really isn't needed. However, the run capacitor can be tuned in the CSCR for better run efficiency where the PSC motor requires a capacitor for both start and run situations. So the efficiency of the CSCR can theoretically be a little bit better than the PSC although from the CEC published test data, they are not all that much different. Personally, I think the PSC is better design since it eliminates one of the primary failures in a pool pump, the centrifugal switch so it should have better reliability.
    Mark
