Thread: Hayward Super II pump question
    mas985's Avatar
    Pleasanton, CA
    Default Re: Hayward Super II pump question
    If you downsized your pump then the new pump could take a little longer to get rid of all of the air in the pump basket. However, any size pump should be able to purge all of the air in the pump basket at full speed in a reasonable amount of time.
    However, if the air never goes away, then you could have a small air leak on the suction side of the pump. Usually this occurs on the pump lid seal but can also occur in the drain plugs or even valves. Given you probably changed some of the plumbing as well, it could be in those sections.
    A few more questions might help:
    What is your old and new pump model/size?
    Are you running at low speed?
    What was and now is your filter pressure?
    What other plumbing was changed?
    Mark
    I will disagree with Mark. You are fine.
    I have that same little bubble on my pump, a 2 speed SuperPump and it has been running that way for 8 years. There's a curve in the top of the clear cover that catches air and can't purge it. As long as it's just that little bubble in the cover you have no problem. You CAN try loosening the cover slightly to try to get some of the air out but I wouldn't bother.
    If it's REALLY sucking air, it will look like a tornado that doesn't quit and be very noisy. Usually that means it's sucking the skimmer too hard and pulling in air. I keep a ball-valve quick connect on my skimmer that I can close down a little if that happens.
    May 2010
    If you had no air related problems before the new pump went in, I doubt that you have an air leak. Usually, if you have an air leak, you will eventually get air coming out of the return lines. You can try opening the filter air relief and see (after the initial air is bled out of the tank) if you get any "spitting" (occasional air) that won't stop, then i might investigate further.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
