Thread: Need to drain my green pool with tadpoles help!
    Default Re: Need to drain my green pool with tadpoles help!
    Hello Theresa, and welcome to the forum! I moved your post here, where it's a little more appropriate--the original forum you posted in was for questions and info about the use of the forum itself........
    Are you planning to drain the pool because you're going to close it, or because of the green and tadpoles? If it's because of the green and tadpoles, it can be dealt with without draining. See this... http://www.poolforum.com/pf2/showthread.php?t=1180
    Maine, USA
    Yep, and it's still going strong without a single problem since then using BBB.
    Regards,
    Ron [ muvipix.com ]
    Thanks Ron, for letting us use your pool as an example of just how effective BBB can be!!
