Results 1 to 8 of 8
Thread: Pump basket lid stuck
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump basket lid stuck
    I don't think "thedurk" is saying it doesn't work. His comment was if it doesn't work, try this.
    Oops. Sorry I missed that. I think I might need glasses.
    Mark
    May 2010
    When the plumbing allows, I stand putting a leg (mine) just to the right of the inlet plumbing, as close to the pump pot as possible as a back up to the counter clockwise force you are exerting on the lid. Your leg keeps the pot basket from rotating with your screw driver (and lid). And steady force usually breaks it loose.
    That, and using marks trick should do the trick.
    When you do get it open, don't make the mistake of lathering up the oring with too much lube. (if your finger tips are anything more than just shiny when you touch it, its probably too much lube). If you hand tighten the lid (not necessarily as tight as you can), and break it loose often, you shouldn't have future problems.
    Good luck.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
