Results 1 to 9 of 9
Thread: lawn turning yellow arround ag pool
    Aug 2010
    ontario canada
    Unhappy lawn turning yellow arround ag pool
    winterized 5 gallon chlorine baking soda last weekend
    got some very unseasonal hot days and very windy on fri 80 k wind burst
    now today sun noticed that 2 3 ft away from the 18in of river rock around the pool the lawn is turning yellow
    Default Re: lawn turning yellow arround ag pool
    Could be over-watering or underwatering. Or chems are leaking.
    What does "winterized 5 gallon chlorine baking soda" mean?
    Aug 2010
    ontario canada
    winterized the local pool store told me to pour in 5 gal of chlorine and some backing soda
    and algizide
    Without current water test numbers, "some baking soda and algaecide" doesn't really mean anything to us. Are you asking if those are the reason why the lawn is turning yellow?
    Aug 2010
    ontario canada
    pool is closed and covered up was just wondering if the chlorine gas building up under the cover would cause the lawn to turn yellow
    as after it was covered up we had a couple of 85 degree days (very unseasonal)
    cholrine 5 gal
    algized 500 mil
    baking soda 2 500 mil box's
    Aug 2010
    ontario canada
    oh yeah lawn is watered with a inground sprinkler system on a timer set for ever 3 days for 2hrs a zone
    recomended by a landscape company
    I don't think you could have any kind of chlorine gas building up under the cover that would turn your grass yellow. It's possible that you could have a leak in the pool somewhere, and that the chlorine in the water that has leaked out might turn it yellow, but if that were the case I would expect to just see it in the area near the leak, not all the way around the pool.
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    I have seen this before, but it was due to the lawn maintenance guys spraying roundup around the pool. The overspray got the nearby surrounding grass.
    Aug 2010
    ontario canada
    thx for your help
    found the source of the prob grass trimmer gas line sprung a leak and i was leaking gas that got on my shoes so now that it has rained grass is turning yellow every where i walked
  1. Water clouds after turning off filter for the night
    By DawizNJ in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-30-2012, 08:07 PM
  2. My pool is now yellow, I'm a bit freaked out
    By Rick Lohr in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-06-2011, 08:09 PM
  3. white fiberglass steps turning yellow
    By Jeffski in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-03-2009, 01:56 PM
