Re: water is not circulating / cannot backwash
CPG, Welcome to the forum. Sounds like it could be a small air leak in the suction side of the pump. This includes the pump basket and lid with the lid being the most likely place. Sounds like the pump isn't pulling enough of a vacuum to self prime. First, with the pump off fill the pump basket with water, close the lid and see if the pump dumps that water. This may also start a normal flow. 'manual priming'. Make sure the lid gasket is clean and get some silicone grease (pool store) and clean and lube the lid gasket. If that doesn't cure the problem an air leak may be somewhere else in the suction side. It only takes a very tiny leak to prevent priming so let us know what you find and we'll work it from there. You can also open the lid, turn on the pump and dump a 5 gallon pail of water into the basket and see if you get any pressure reading on the gauge. If that water comes out your returns then there is no pressure side blockage.
