waterbear
If your water level drops when running the spa jets then start looking for a leak or possibly a back check valve in the spa return line.
Adding dry acid "a little at a time" is not going to do the job. You need to drop the pH to 7.0, test TA, then aerate to bring it above 7.4 and repeat this until the TA is on target. You do not need to aerate but it will take longer for the carbon dioxide to gas off. There are other ways to aerate besides using your spa jets BUT if your water level drops when running the spa jets then start looking for a leak or possibly a back check valve in the spa return line.
