Results 1 to 10 of 16
Thread: High CYA and algae
    Jun 2011
    Kansas
    Default High CYA and algae
    I don't have a good test kit yet, but I will post what my Wal-Mart test kit is telling me. I have a 30,000 gallon in ground pool with a vinyl liner and I am a first year pool owner.
    Total Chlorine is between 5 and 10
    PH is 7.2
    TA is 110
    CYA is 100
    All my levels where good, but my water was cloudy so I shocked the pool and added 4 or 5 chlorine tablets (both bought at Sam's). My PH was actually a little low (7.0), so I added some PH booster. Now my CYA is really high and I can't clear up the water because of algae. What would cause the CYA to spike like that?
    We have had the pool open since the beginning of May. We finally had the water clear about three weeks ago and have been fighting it ever since.
    This used to be my grandparents', then my sister's and now mine. Their answer is to shock the heck out of it, but that just doesn't seem right to me.
    Please help!
    Default Re: High CYA and algae
    The chlorine tablets that you're using are what's causing the CYA to spike, and what's causing your pH to be low. I would stop using any stabilized form of chlorine and use plain, unscented bleach. You do need to shock the pool, since your CYA is 100, that means getting your chlorine up to 25 ppm and holding it there until the pool clears by testing and adding more chlorine (bleach) as many times daily as possible. In a 30K gallon pool, each 2.5 gallons of 6% bleach you add will raise your FC by 5 ppm. Each 1/2 gallon will raise it by 1 ppm. Keep the filter running 24/7 during the process, and clean the filter as indicated by your pressure rise. Once you can hold chlorine at the 25 ppm mark overnight, and the pool is clear, then you can let the chlorine drift down, but never below 8 ppm since the stabilizer is so high.
    Jun 2011
    Kansas
    I have been doing a little reading through this forum and it seems to me that the CYA never goes away like chlorine does. If that is true, why do they put it in with the shock and chlorine tablets? Also, what is the ideal amount of CYA?
    I am supposed to have a pool party on Saturday and I want the water to be swimmable. I am not that worried about the water being clear, but I don't want to have so much chlorine in the water that they can't swim. Is this going to be possible and still be working on clearing up the water?
    Jun 2011
    Kansas
    I just have a wal-mart drop test kit and some test strips. Our pool store doesn't carry the Taylor kit. Is there any other way to test the chlorine to 25 ppm? I'm ordering the Taylor kit, but I don't know how long that will take to get here.
    Thanks,
    Ty
    The ideal CYA for most pools is around 40-50. CYA sometimes goes away over the winter but not always. However, during the summer, once you get your level where you want it, you are pretty much done with worrying about it for that season.
    What ingredient is in the shock you are using? Do you have a reputable pool store that can test a water sample for you? But, don't buy all the stuff they will try to sell you. Usually it just makes things worse.
    Until you can get a test kit, you can force your drops-based kit to read higher by using a dilution method described below. It is not meant to replace getting a good kit as it is not super accurate.
    Testing Without a Good Kit
    In order to test high cl levels, you DO need the Taylor K-2006 or 2006C which is the same kit but with 2-oz. bottles of reagents insead of 0.75 oz. But, their website is down today. Ben talked to them this morning and they do have kits in stock, but you'll have to phone in your order instead of doing it online until their site is back up. The phone number is 800-992-6286.
    Jun 2011
    Kansas
    I have been using the PoolBrand Quick Dissolving Shock-24/1 lb. pouches and Chlorinating Tab's made by PoolBrand from Sam's. I just read the label and they both say they are Stabilized. Should I just throw these away since they just keep adding more and more CYA? Or, is there a way to use these without the CYA rising? We had just bought a box of the shock and I hate the idea of throwing away $60.00.
    Also, with the chlorine level at 25ppm, will the water be swimmable tommorow?
    Thanks,
    Ty
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Quote Originally Posted by tyandnikki View Post
    PH is 7.2
    TA is 110
    CYA is 100
    Please help!
    Your CYA may very well be HIGHER than 100. My understanding is that the turbidity (black dot) CYA test is only good up to around 100... over that, and it may be much higher than the test can show. If it is... you may need to dump some water to get it to a manageable CYA level. I'll let others-- more experienced-- recommend a course of action for that. My concern is that it will be difficult to maintain high enough CL with a CYA of 100+ and you will likely get recurring algae problems. Happened to me years ago before I found this forum and the BBB method. Good luck with this-- it is fixable and then your pool will be much easier to maintain.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
    Jun 2011
    Corpus Christi, TX
    I used to buy my pool shock(er) at Sam's too. They carried the Pool Brank Quick Dissovling Shock:
    MSDS:
    link removed by moderator so I could mod the post in quicker.
    EDIT by moderator: The MSDS sheet showed that the product has dichlor in it.
    If it has stabilizer (CYA) in it, you should not be using it. Just use bleach. Don't throw them away. Close them up and you can use them next year if your CYA drops over the winter.
    Do you have a reputable pool store that can test for you? We need a CC (combined chlorine) reading.
    Also, do you know how much chlorine you lost overnight from sundown to sunup?
    I know your party is tomorrow, but it is unlikely that your chlorine is going to come down much between now and then. I wouldn't want to invite people to my house to swim in my pool where I was fighting something in the water. The high chlorine level won't hurt people really but they should wear their old suits.
    I wish that you had come here to the forum sooner than yesterday. It is kinda hard to help somebody clear up their pool in 2 days. I know you can't for tomorrow, but you might want to consider doing a partial drain and refill and try and get that CYA to a more manageable level or you're gonna struggle with having to run really high shock levels anytime you do have any problems (which will be any time your chlorine drops lower than 8.) If you haven't already done so, take a look at the Best Guess table in my signature below where it explains the correlation between CYA and chlorine levels.
    Especially if you decide not to do that partial drain but instead are just gonna live with that high CYA, having the good kit is imperative!
    I'm sorry we aren't being more help, but the time frame is just not enough to adequately take care of this properly.
    Jun 2011
    Kansas
    Thanks so far for everyone's input. When my grandparents had it, they would just keep shocking it until it cleared up. Once the water was clear, their weekly process was to shock it every Sunday night or when it rained. I think that was their only source for chlorine in the pool I don't remember then using the tablets. So, I guess the chlorine from the shock would deminish over the week. Kinda of an up-down pattern in the chlorine levels. I would think that a steady amount of chlorine would be better. They used the same brand that I have been buying from Sam's and I have to say that their water was almost always clear. My sister followed the same routine when she ran it for about 5-6 years without much of a problem. They very rarely had a algae problem.
    So, I have both my grandparents and my sister telling me that I need to add more shock and to keep shocking it until the pool clears. This goes along with what you all are telling me on here, but it also seems that I already have or I am developing a CYA problem. Is there another way to test the CYA besides the black dot test to make sure what level it is at?
    Thanks again,
    Ty
