Results 1 to 8 of 8
Thread: Waterproffing pvc pipe thru cinder block pool
    Nov 2010
    South Florida
    Default Re: Waterproffing pvc pipe thru cinder block pool
    Hey, Thanks for the response. I will try to take some pics and post this weekend. I might try that bag trick with the hydrolic cement.....I thought about doing that but thought it might be easier to use the poly caulk. I'll keep you posted.
    Thanks again.
    East coast
    Sika makes expandable foam. Its just like The Great Stuff foam. Use it for the hollow inside of the block as a filler then pack around the pipe with Hydraulic Cement. Quickcrete has one from Lowes.
    38000 Vinyl IGP filled w/ well H20, SWCG-CI40, DE Filter, Elec. heat Pump
    24x40 rectangle 36K gal IG pool; SWCG; Pentair DEQuad DE filter; Hayward pump; 12hrs; ColorQ Pro by Lamotte; well; summer: ; winter: ; iPhone; PF:3.3
  1. Want to build block pool myself someday
    By MrWhite in forum In-Ground Pool Construction and Repair
    Last Post: 06-04-2013, 09:24 PM
  2. Any experience with "pool-in-a-box" kits? Cinder blocks, pt wood, etc.?
    By Corporate Dog in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2012, 01:46 PM
  3. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
  4. Cinder blocks as weights
    By TimWillin2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-28-2006, 03:46 PM
