Re: Chlorine high on Salt System - Help
I'll let those with SWCG experience chime in on this one, but just wanted to throw an idea out there for consideration........
Don't forget that as your water temp drops, your chlorine will take much longer to dissipate--I've gone from adding a couple of gallons of bleach a week to only one gallon every couple of weeks and still maintaining 10-12 ppm chlorine. So it seems to me that unless your chlorine generation is very, very low, you're going to have high chlorine levels throughout the winter, and I don't know how low you can set them. Don't know where you live or if you use the pool during the wintertime, but maybe you should consider cutting back the run time to only a few hours/day, if you're not using the pool?
