I always drain a couple of inches below my returns.
thanks, I was just a little concerned because I am draining so much water. My shallow end looks to be about half empty. Just got back from the pool store ready with new plugs.
30000 gal 20*40 vinyl IG pool w/sand filter. ROLL TIDE
Hi and welcome to the Forum!
2- 3" of water in the shallowest part of your pool should be enough to keep the liner 'set'Sounds like you've still got a couple feet of water, so it's all cool
The only issue is if you have a high water table or this winter's snow/ rain won't refill the pool before the ground gets saturated with water - in that case, the liner might float
I'm not trying to scare you, I just want you to know that the pool should be ~ full before the melt-off and spring rains occur
We're here all year long and you can ask us any questions you have.
Take care, and I hope you have a great winter!
I have an IG pool too and never drain below the skimmer bottom initially and let it creep to mid skimmer. I do blow the return lines, plug them and pressure test for leaks, suck the skimmer line dry and fill it with anti-freeze, and pack the skimmer with foam pieces because it will fill with water and freeze. I try ane keep the water level high for the reasons Ted mentioned about the water table. Have a Merry Christmas.
