Thread: automatic control of SWG?
    Default Re: automatic control of SWG?
    Sorry...a bit of searching = aqua rite pro with aql-chem / sense & dispense option seems like what I'm looking for.
    Anyone have good/bad experiences with the sense & dispense option?
    Thank you -
    It still won't eliminate water testing if that is what you are trying to do. As far as it goes, once a SWCG is set properly the FC stays pretty constant as long as the water parameters ( pH, TA, salt level, CYA) are kept fairly constant. ORP control will not really make that much of a change and pH can be kept under control fairly easily by keeping the TA low and adding borates to 50 ppm. Using ORP and pH controllers just introduces new headaches, IMHO, since they will need to be checked and calibrated and the electrodes replaces on a regular basis. You are really ADDING additonal maintenance to the system, IMHO.
