Results 1 to 9 of 9
Thread: Pump Will Not Maintain Its Prime
    May 2010
    Default Pump Will Not Maintain Its Prime
    I have a Whisperflo 2HP pump for my Sheer Descent waterfall. It has been operating flawlessly for two years. It recently started losing its prime and the pump pot would intermittently fill and partially empty with water, causing an inconsistent flow to the waterfall. I’ve inspected the lid, lid gasket and piping for cracks and all seems ok. I’ve attempted to feel for debris in the impeller but can’t reach that far into the pump.
    After re-filling the pump w/ water and re-starting, it appears to operate fine for a few minutes and then the inconsistent emptying and filling of the pump pot starts again. The pump never stops pumping, but continues to pump intermittently.
    Default Re: Pump Will Not Maintain Its Prime
    Welcome to the forum!
    From where does the water feed the pump? I suspect a dedicated main drain, check to see that it's not obstructed.
    An air leak on the suction side would also cause this, try dribbling water on the lid, influent port and any valves, unions or fittings you can see above ground. If the air in the pump housing lessens when water is poured on a certain area, that's an air leak and we'll help you address it
    May 2010
    Thanks Ted, I'll check those out.
    Sep 2010
    Lemoore, CA
    Not to thread jack... but I was wanting to post the exact same topic and am looking for more insight into this problem.
    My pools main pump is losing its prime. It was a problem I had a few months ago when first starting the pool up (my first year with the pool/house). But in the last month of two it has held pretty consistently until yesterday. The pump lost its prime almost as soon as it fired up and I caught it pretty fast. Re-primed pretty easily and it ran fine the rest of the night.
    I came home today, the pump had been running about 2.5 hrs, and at some point it lost its prime again. The water was steaming hot and the basket was empty... Is there an ideal adjustment on the valves to avoid this problem? I have a skimmer, cleaner, and drain line for inputs. Waterfall and jets as outputs...
    I guess I'm totally thread jacking here, I apologize. I can repost a new topic if that would be better..
    Honesdale PA
    Smearing some vaseline on PVC pipe joints (not gaskets) may be a little easier to use than water for finding a leak because it's simply thicker. Wipe it off when done. It won't hurt PVC but isn't recommended for gaskets.
    I know this is one of those "no-duh" things, but have you made sure that the water level in the skimmer is sufficient?
  1. New pump won't prime
    By ButchM1 in forum Pool Equipment & Operations
    Last Post: 05-18-2012, 12:32 AM
  2. can't keep prime in pump
    By PFPAM in forum Pool Equipment & Operations
    Last Post: 06-28-2007, 08:35 PM
  3. Can't get pump to prime
    By Pamsel in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 10:47 AM
  4. Dead Pump: How to maintain chemistry?
    By Ken and Laura in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-30-2006, 11:58 AM
  5. Pump problems... Hard to prime and air in the pump lines
    By tinyprotagonist in forum Pool Equipment & Operations
    Last Post: 06-29-2006, 11:38 PM
