Thread: Sources of Calcium
    Sep 2010
    Lemoore, CA
    Default Sources of Calcium
    I live near Fresno, CA (Naval Air Station Lemoore, CA to be precise) and am having trouble finding inexpensive sources for raising my water's calcium level. I checked Lowes and Home Depot and have been making calls looking for calcium chloride. I get alot of blank stares, maybe because
    I took a sample to the pool store and they weren't too concerned. It tested somewhere between 50-100 for them, comparable with my own 60-70 reading. The pool is a gunite, pebble tech style pool at about 23,000 gals.
    What should I be looking for? The pool store sells CA at $10/#6 or $25/#15... looking for a cheaper option, not sure how much its going to take.
    Default Re: Sources of Calcium
    Calcium chloride is also sold as "de-icer" in products such as Peladow, Dowflake and Tetra often found in hardware stores. Of course, leaving in an area that may not freeze makes it less likely to find such products.
    Sep 2010
    Lemoore, CA
    I found a source! The local pool store sells 15lbs for $25. I found a cement and landscaping shop in Fresno, just down the highway from me, that sold me a 50lb bag for $30. And he claims its between 94-97% Calcium chloride. I'm excited! Now I just have to figure out how much to add!
    Use The Pool Calculator where in the CH section use "calcium chloride" not "calcium chloride dihydrate".
  1. Cost Comparison of Chlorine Sources
    By chem geek in forum The China Shop
    Last Post: 06-26-2013, 03:10 PM
  2. Sources for pool coping and tile
    By GaryDG in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2011, 09:50 PM
  3. Sources of Metal
    By MrSparkle in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-29-2007, 07:48 AM
  4. Using other sources for pool equipment
    By NomenNescio in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 03:08 PM
  5. Ascorbic Acid SOURCES
    By johnsislandpool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-27-2006, 08:44 PM
