Re: Help
Hello, and welcome to the forum from a fellow Louisianian!!
To clean your pool is easy--to decide when you want to do so is really up to you. The cleanup process will involve using plain, unscented bleach to get the pool up to its shock level (which will be determined by your CYA level, if you still have any) and then continuing to add the bleach to keep the pool at shock level until the green clears up. This is done while brushing the pool daily, and while keeping the pump running 24/7 and cleaning your cartridge as your pressure increases. Keep a good eye on the filter pressure, though--in a really algae filled pool it can tend to build up quickly, especially at first. Once the green is cleared up, then it's easy to get the rest of your chems balanced.
Has the pool been drained for the winter? If not, are you running the pump during this next couple of days until this cold snap is over? Burst pipes are a real worry for right now, with sustained temps below 30 for the week. So--if you're going to run the pump anyway to keep the pipes from freezing, you might want to go ahead and shock it/clean it up now. IF not, then you can just wait until the weather starts to warm up again--if it's green and yucky now, then it won't be any worse if you wait another month or two.
Let us know what you decide to do, and we'll be glad to help you take it from there!! What size pool (in gallons) do you have, and what is your CYA level?
BTW, I'm going to delete the duplicate post that is attached to the "green disgusting pool" sticky. If you'll make any new posts on this topic as a reply to this one, it will be much easier to keep all of your pertinent info together.
