Our weather is finally getting nice and we are ready to begin the Swamp Cleanup!! My readings are:
Chlorine 0.2
PH 8.2
Acid Demand-2 gallons of Muratic Acid
Alkalinity 170 ppm
Chlorine 0.2
PH 8.2
Alkalinity 170 ppm
Is there a lot of debris in the pool that can be scooped out? If so, get a net and get as much out as you can. You'll want to take your chlorine up to shock level and try and hold it there as consistently as you can. Do you know your cya reading? For now until we know your cya reading, I'm going to recommend that you raise your chlorine level up to 15ppm. In a 30K gallon pool, each gallon (4 quarts) of 6% bleach will raise your cl reading by 2ppm. Test at least three times per day and each time, add enough bleach to get back up to 15ppm. Also run your pump 24/7. You'll also want to work to get your pH down. Add doses of muriatic acid until you get your pH down to around 7.2. Each 24 oz. dose will drop your pH by about 0.2. Don't try and do it in one big dose. Be careful with the acid. It is nasty stuff. Don't get it on you and be down wind of the fumes.
If you don't have a good test kit, you'll want to get one. The one we recommend is the Taylor K-2006. If you buy it from Amazon through the following link, the Pool Forum makes a little money in the process. http://www.poolforum.com/pf2/showthread.php?t=10006
Keep us posted how things are going.
There is no debris, just a lot of algae. I took pictures yesterday and will try to figure out how to load one today. We are getting bleach and acid today. The filter is a Hayward 4500C cathridge filter. We also have skimmer filter baskets. I also ordered the Taylor kit though the link you provided. I will get CYA today as well!!
Don't add any cya yet. We need you to get a reading before adding any. Also, even if your cya is low, we won't want you to add it yet. After the algae is cleaned up is the time to do that. You're probably going to clean those filters frequently while you are cleaning this mess up. Also, run your pump 24/7 while you are fighting the algae. The more consistently you can keep the chlorine level up, the faster this clean up will go. Test as many times a day as you can, and each time bring the cl back up. There is no such thing as testing and adding bleach too often.
CYA number was 100. The pressure on pump was 15 this afternoon, so, I didn't startt adding bleach yet. Filter can be cleaned in the morning. I can go ahead and add the bleach tonight, but thought the filters may need cleaning first. How can I send a picture of "my swamp"
A CYA of 100 is WAY too high. And, in actuality, it may be much higher than 100 as that is as high as most test kits can register. Please do NOT add more CYA. I bet the previous owner used trichlor pucks for the source of chlorine for this pool. Trichlor is stabilized and adds CYA with each puck added to the pool. The only way to lower the CYA is to drain and refill. Having said that, you don't ever want to totally drain a pool, especially in a swampy place like Louisiana. Doing so can cause the pool to pop up out of the ground.
You have a couple of options. Option 1 You can either slam it with bleach and eradicate the pool of algae now and then once the pool is clear, you can do several partial drains and refills until you get the CYA to a more manageable level. (Unfortunately, it will take a lot of water replaced probably a couple of times. In a big pool like yours, that may be a substantial amount of water.) if you decide to do this, it will take shocking it way higher than 15 as I originally suggested. With a CYA that high, you'll need to keep the chlorine level at 25-30 to kill the algae. (Required chlorine levels depend on the CYA level in a pool.)
Option 2 is to go ahead and do the partial drains and refills now before adding the bleach. Then, you can attack the algae later. (That will save you some money in bleach.)
Option 3, and the least desirable one in my opinion, is to live with a high CYA level. But, you will have to run higher than normal chlorine levels as a result meanng that you will always have to keep your chlorine between 8-15 all the time or you risk another algae bloom.
Let us know what you think and we'll wallk you through any of these options.
The good news is that once you get the CYA level down to a more manageable level, we can teach you how to keep this from happening again.
I will have to go with option 1 as I have started the bleach. I put in 18 gallons of bleach Monday and the pool has gone from yucky green to the cloudy pale green. I have been sweeping the sides and floor down as much as I am able to. I tested the water every 2 hours Monday and added bleach if it dropped any. I am using a kit from Walmart and I have ordered a Taylor pool tester kit to be able to get better readings. I will add more bleach tonight and just go from there. As soon as the Taylor kit gets here, I will send you my numbers.
If you have any other suggestions, let me know and THANK YOU!!
