Results 1 to 9 of 9
Thread: Miraclear Clarifier
    godstreasures1 is offline ** No working email address ** godstreasures1 0
    Ga.
    Default Miraclear Clarifier
    I use bleach in my 24ft above ground pool. It took me forever to clear up the winter mess this year. I have just got the water sparkling clear and I want to keep it that way. I saw in a pool catalog a product called miraclear. It is a gel shell that you put in the pump basket. It is suppose to keep the water clear for a month. My question is has any one used this or other similar items? I was thinking about trying this.
    duraleigh Guest
    Default Re: Miraclear Clarifier
    "Dance with who brung ya' ", as my grandma used to say.
    Keeping your chlorine level where it is suppose to be will keep your pool clear. Remember, high pool usage can stir up debris not filtered by a sand filter. de filters do a better job of filtering out the small stuff. remember this, a lot of swimmers will result in a cloudy pool for about a day. i hope this helps.
    there are no magic bullets to get a clear pool except keeping it properly chlorinated. those other products drain your wallet and make easy dough for someone else.
    good luck
    Ft Lauderdale, Fl
    Miraclear is a sister company of AutoPilot. This is designed as a clarifier with some algaecidal properties. It really does work as the gel does not dissolve readily and slowly releases clarifier to your pool.
    As suggested, keep your water chems, circulation, and filtration in proper order and you shouldn't need it. However, it you want to use it as a preventative measure, it will not do any harm and will help to filter out finer particles.
    Sean Assam
    duraleigh Guest
    Hi, Sean,
    It is not clear to me (no pun intended) how clarifiers work. What do they do? How is it algaecidal? I recognize you're not saying "use it" but I'm curious as to how they work.
    Ft Lauderdale, Fl
    Clarifiers work to "clump" dirt to filterable sizes. The Miraclear has some Copper sulfate in it as an algacide. I don't mention "use it" because I don't want to cross the fine line of "selling". But I did say, you don't NEED it in a clean, clear pool, but if you need a clarifier, by all means, it's a fantastic product, according to what the service company feeds back to me.
    Personally, I have never had to use it on my pool, but I have used it on my cousins out-of-control pool and it does work.
    Sean Assam
    So, is it possible to over-clarify your pool? What I mean is use too much clarifier? My pool is super cloudy and I have used lots of clarifier, which has worked pretty good.
    -Crystal
