Results 1 to 10 of 15
Thread: Pool Opening - PS234 Test
    Maine, USA
    Default Re: Pool Opening - PS234 Test
    OK, I checked my numbers this morning and my PH shot up for some reason
    FC - 14
    CC - < .5
    TC - @14.5
    PH - > 8.2 ?
    Alk - 110
    Maybe the bleach added the extra PH? Should I apply a bit of muriatic acic? If so, how much? A quart to start?
    The water is looking a little better, but I still need to vac some more.
    Regards,
    Ron [ muvipix.com ]
    Double check your ph reading. If it truly is that high, then yes, you should add some muriatic acid.
    Maine, USA
    Thanks again. Got it down to between 7.5 - 7.6.
    FC - 11
    CC - < .5
    TC - @ 11.5
    Alk - 110
    Still filtering/vacuuming. Even when I'm not vacuuming, I have to backwash every 20-30 minutes or so. Lots of dirt.
    Thanks for everything thus far!
    Regards,
    Ron [ muvipix.com ]
    Maine, USA
    PH - 7.6
    Alk - 90
    FC - 8.5
    CC - 0
    TC - 8.5
    Took cover off:
    10 minutes later with initial 'shock':
    Day 2:
    End of Day 2:
    10 minutes ago (day 3 - AM) after vacuum/brush
    This is the final:
    Even a drastic difference from the last one above. All of my numbers are perfect (MO) and I'm using up some pucks from last season to start getting my CYA up. Other than that, it was bleach (@7 gal.) and 1 box of borax for my opening 'stuff'. A far cry from past years 'kits' from the local pool store ... done with that
    Thanks everyone! Couldn't have done that without this forum or the PS234!
    Regards,
    Ron [ muvipix.com ]
    Maine, USA
    I couldn't edit the original posts, so I revived this old thread and fixed the links.
    My pool is still going strong after all these years and still using the BBB method exclusively. Added solar panels, had the liner and pump replaced.
    Just opened mine about 2 weeks ago with about the same results as those pics.
    Regards,
    Ron [ muvipix.com ]
    I merged the new links into the old post, and deleted the other . . .
    Maine, USA
    Hi all,
    Still going strong. Will be opening mine soon (been kind of a chilly spring in Maine so far). I'm thinking of maybe doing a time-lapse for the open, we'll see.
    Can't believe that it's been more than 10 years since I joined this forum.
    PoolDoc, Watermom, etal,.. hope all is well!
    Regards,
    Ron [ muvipix.com ]
  1. opening pool - water test results
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 10:55 PM
  2. Opening the pool a little early. Here are my test results so far.
    By bri3180 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-19-2013, 01:24 PM
  3. Opening pool test results
    By GregP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-18-2012, 11:37 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. first pool, first test with the ps234
    By dhale63 in forum DPD-FAS based testing
    Last Post: 05-08-2006, 11:12 PM
