Results 1 to 10 of 15
Thread: Pool Opening - PS234 Test
Threaded View
  1. #10
    Default Re: Pool Opening - PS234 Test
    Double check your ph reading. If it truly is that high, then yes, you should add some muriatic acid.
  1. opening pool - water test results
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 10:55 PM
  2. Opening the pool a little early. Here are my test results so far.
    By bri3180 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-19-2013, 01:24 PM
  3. Opening pool test results
    By GregP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-18-2012, 11:37 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. first pool, first test with the ps234
    By dhale63 in forum DPD-FAS based testing
    Last Post: 05-08-2006, 11:12 PM
