Thread: Maintaining an out of State Pool
    Mahwah, NJ, USA.
    Default Maintaining an out of State Pool
    Any suggestions for maintaining a pool in a 2nd home? The BBB method works great for me here in NJ but I am going to need to maintain a year round (FL) pool and will have to get a service. I just don’t think I will be able to find a service that uses the BBB method.
    Would salt be easier to maintain than chlorine?
    Anyone in a similar situation?
    thanks
    Default Re: Maintaining an out of State Pool
    I would think that salt would definitely be easier to maintain than BBB--as long as you have someone to make periodic acid additions and check your salt levels, it should be pretty maintenance free, from what I understand.
    My biggest concern would be having someone there that can shut off the pump in case of low water levels, or to empty the skimmer to keep from forming an obstruction in the basket......
    Mahwah, NJ, USA.
    I have a reletive around the corner. I believe the pool has an automatic water feed when it gets low. I will definitely need some type of pool service I am jsut trying to minimize being "pooled" and having a bunch of stuff added to the pool that I don't want or need.
    thanks for the reply.
  1. Maintaining FC level, help me understand.
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2009, 10:18 AM
  2. On maintaining FC...
    By docsobeck in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2009, 08:52 PM
  3. maintaining heat in pool
    By katatonic in forum Pool Equipment & Operations
    Last Post: 05-14-2007, 09:37 PM
  4. First post - Trouble maintaining Chlorine
    By ubalr1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2006, 10:59 AM
  5. Maintaining Chlorine levels during early spring
    By Lenny in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-08-2006, 01:23 PM
