Thread: Emergency Shutdown
    Aug 2010
    Central Texas
    Default Emergency Shutdown
    Had a leak on the filter backflush side and had to do an emergency drain of filter and pump due to freezing temps. Not sure if its just the gasket or what. My question is this: Until I get the leak fixed can I still add bleach without the water circulating? If I walk around the pool and scatter the bleach around will it be ok?
    Default Re: Emergency Shutdown
    You can scatter the bleach around--it's better than nothing!! Be careful not to splash it on the sides or anything else that might stain--and you might want to consider following it up with a good stirring by your pool pole or a broomstick.
    Wear old clothes!!
    Lehigh Valley, PA
    I usually add bleach by broadcasting it across the surface from a plastic pitcher, which avoids getting a heavy concentration in any one place. During the off season, when the pump isn't running, I drag the leaf net on the pole through the water a few times to stir things up. This does a good job of disseminating the bleach throughout.
    Sorry to hear about your equipment breakdown.
    May 2010
    Central NJ
    Not to resurrect such an old post for sake of it, but because the date and topic killed my just back self! In the 5 weeks prior to this post I had way over 60" of snow. I can't imagine (LOL), "shovel out a path, drill a hole, using a hand blender of sorts and a funnel..." "consider covering a pool when the filter is not running to avoid the urge to ice fish..." albeit, my huge pool savings last summer easily paid for my XC skis!
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
  1. Is stabilizer needed late in the year for shutdown?
    By Pibster in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-13-2012, 12:10 PM
  2. Emergency help needed
    By cdocon in forum In-Ground Pool Construction and Repair
    Last Post: 03-20-2012, 10:33 PM
  3. Normal for DE to be in pump strainer after shutdown?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-12-2007, 12:18 AM
  4. Dead pump emergency
    By ljh in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2007, 09:32 AM
  5. EMERGENCY! Pool liner collapse
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 03-06-2007, 08:47 AM
