Thread: NEW Pool question
    Dec 2005
    Default NEW Pool question
    I just had a new pool constructed . They filled it with water last week. Initially the water was pea soup and we could not see anything. it cleared up this weekend. When the pool light is on the pool floor is horribly uneven , it looks like the kentucky rolling hills. We also had the Paramount PCC2000 pool cleaner installed and each head was plastered like a mini volcano. Instead of having the head cut even with the floor it looks like they were all cut high and they didn't even try to smoothe out the bottom to make level.
    Here are a few links to some pics.. Quality isn't that great since the pool is still slightly green. But the water is dead calm, anything you see is the actual bottom and not water.
    http://i1229.photobucket.com/albums/...2-11183124.jpg
    http://i1229.photobucket.com/albums/...2-11183339.jpg
    http://i1229.photobucket.com/albums/...2-11183347.jpg
    Scott
    Default Re: NEW Pool question
    Have you actually felt the unevenness of the surface or does it just look that way through the water?
    Dec 2005
    oh its there..
    Can't see it during the day but side lit it looks like I did it myself.
    The Pool company came out there yesterday and took a look at it (they outsource the finish to another company) . They ended up draining it (12k gallons to the neighbors empty lot) and are refinishing it today.
    I never received a proper explination as to what happened but hopefully its not worse this time.
  1. Question about above ground pool vac and pool pump timer from newbie.
    By momtoallgirls4 in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 02:06 PM
  2. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
  3. Question on used AG pool
    By yjjeeper in forum Above-Ground Pool Construction & Repair
    Last Post: 12-25-2006, 01:57 PM
  4. Well under pool question
    By iardon in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 09:02 PM
