Please help me avoid last year's mistakes
Okay, my husband finally drained & cleaned our pool. It is an aboveground round Intex pool. (There is more info in my signature line.) He is replacing the rope around the bottom of it and then will soon be refilling it. We are starting with fresh tap water. I'll run some stats on the chemistry of our tap water with our Taylor test kit & post them in a reply to this post later today. Or should we fill the pool & then draw the test sample from what's actually in the pool? We don't want to make the mistake we made last year of using pool chemicals & wasting so much time trying to "balance" that we ignore chlorine & end up with a green pool right at the start.
What is the best way to add stabilizer? We do have some of the "pucks" but I understand they aren't best. Should we plan to just buy some stabilizer by itself? If so, how will we know how much to add? At what point should we start adding bleach?
Any help in getting off on the right foot would be appreciated!
Tricia from South MS
Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
