The cell cord is just a compression fit onto the cell prongs. You should be able to wiggle the cell plug, but grasp it at the thicker rubber part, rather than the cord, while you're lifting it off.
Yes, you can also use a flat bladed screwdriver to wedge the cell cord off.
However, you may find some corrosion between the cell plug and prongs. This can occur as a result of moisture getting in the cell plug.
