The low amps and low volts indicate that it's not getting a signal to activate the cell. Check the programming of your system to see if under Set Relay, is it set for Remote Runs Pump. This is only used if you are using an Electronic Control System to control the salt system. You should be set on External Timer, or One Speed/Two Speed Pump.
Another possibility is the top right fuse that goes to the control board.
