I personally am a sand filter fan....my sand filter does just as good a job as any DE filter could, and if I needed better filtering, I can always use a handful of DE to get the benefits of the DE filtration without the hassle--this is a trick that the other 3 mods all use with their sand filters. Just make sure that if you do replace your filter, that it is adequately or over-sized for your pool and pump--many people make the mistake of buying undersized filters, and that will result in the pump just pushing the filter media back into the pool.
