Re: DE in pool
I have used de filters in the past and have found that it will find its way through any areas that it can into the pool, especially after a pump start up when it is wanting to adhere to the grids and there are any holes bigger than a pin in the mesh.
Reason: oops! hit the edit button instead of the reply button!
