You're pretty good with your assumptions!Except for having to drain the pool - I've been able to do it 95% of the time without having to get in the pool (draining was never done).
Your old light has a 'halogen' bulb, most of them I've seen are Pentair. If you go with another brand's light, you may need to go to the hardware store and get a slightly longer screw for the 'set screw'
If you pull the lights yourself, don't forget to secure the string to the light cord with electrical tape(and I'll still give you a couple of other tips on pulling and reconnecting a light
