Results 1 to 10 of 12
Thread: Pentair Intellibrite vs Hayward Colorlogic
    Default Re: Pentair Intellibrite vs Hayward Colorlogic
    Most (read ALL) lights have a flooded conduit, unless ground shifting/ freezing has compromised the conduit, in which case, someone may have puttied the niche to stop the leak and you'll have to remove the putty to pull the old cord out and install the new one, and then re-putty the niche when you install the new light.
    The wires are very simple, the black one carries the current, the white one is neutral and the green one is the grounding wire. At your junction box, just make note as to which color wire attaches where and replicate that when you install the new cord. (but you sound like you know electricity far, far better than I)
    When I pull a light cord, as you suggested, tie a string to one of the old cord's wires (and tape it) and pull the old cord out. If it's tough to pull the old cord out, either the electrician used a small conduit or the conduit has broken somewhere and the broken pieces are pinching the cord .
    When going to install a new light, I unravel the cord - I walk around the pool 'unwrapping' the cord, so that there are no 'kinks' to get stuck at the back of the niche, where the conduit attaches
    It helps to have someone 'feed'/ force the cord, if it get's stuck (YOU DO NOT WANT TO BREAK THE STRING!!) A little lube on the first couple of feet of the cord helps.
    Maybe I helped with this, maybe I didn't - if you need more of my advice, simply ask
    Largo, Florida
    I got the pentair intellibrite 5g. It's pretty groovy. Like I've seen on other posts, the red is a bit dim; for the price they charge they should fix it. Otherwise it's perfectly bright for my pool. On white it's a bit brighter than the old light with two 100w halogen bulbs, and it's really white so the pool looks blue at night instead of green (although it does have various shades of green you can choose if you so desire).
    Turns out the niche in my pool is an off brand according to the pool guy and moreover is not installed correctly - I guess the screw hole is supposed to be at the top (to screw the light in) but instead it's at about a 2 o clock position.
    The pool guy actually charged me less for the light than I was able to find it for online and with labor it was 600.
    Largo, Florida
    Pics:
    white
    green
    purple
    white
    There is something a bit odd that you can't tell in the photos. When the light is set to white, it is actually a combination of all the LED's including the color ones. The light emitted from it is definitely white but you can easily see the rainbow of LED colors when you look directly at the "bulb".
    The color changing mechanism with this light is to turn it on, then cycle the power switch a specific number of times to choose colors (or buy an expensive controller). It's not as much of a hassle as it sounds like, but I'm definitely going to have to copy the page from the manual and get it laminated to attach to the wall next to the switch.
