Thread: Rust stains caused by coins!
    Default Re: Rust stains caused by coins!
    ok -- it would be interesting to know if VitC removed those . . .
    I assume this is a plaster or fiberglass pool, correct? If it is then the following applies:
    Maybe the zinc, copper is doubtful. For those, dry acid in a sock might work. But try the vitamin C first. No need to crush it, Just put a handful in an old white cotton sock and hold it on the stain. If it is going to work it will do so in a minute or less. Use your pool pole to hold the sock on the stain if you can't reach it otherwise.
    If that doesn't work put a handful of dry acid into another old white cotton sock and hold it on the stain for up to 30 minutes.
    In any case, adding a double dose of metal sequestrant can help over time.
    If you have a vinyl pool then you can use the vitamin c but do NOT try the dry acid!
