Thread: Pump losing prime but only when vacuuming
    Default Pump losing prime but only when vacuuming
    The pump primes fine under normal conditions and when back-washing, but when I vacuum it loses prime in about 1-2 minutes. If I turn off the pump and wait 15 seconds and turn it back on, it primes fine again for a few minutes. The vacuuming hose is attached at the skimmer. Could this be an air leak in the hose?
    Thanks,
    C
    Default Re: Pump losing prime but only when vacuuming
    Thank you for your reply, I'll try replacing the hose and see how it pans out.
    Thanks,
    C
  1. pump slowly losing prime
    By sjpoolowner in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 05:11 PM
  2. Losing Prime when vacuuming
    By dbell525 in forum Pool Equipment & Operations
    Last Post: 05-28-2010, 04:32 PM
  3. Pump Losing Prime
    By ChiInSFO in forum Pool Equipment & Operations
    Last Post: 08-08-2006, 03:30 AM
  4. Pump Keeps Losing Prime
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 07-26-2006, 01:00 AM
