Thread: How often to test
    Default How often to test
    Have added muratic acid to lower TA, when do I retest?
    Default Re: How often to test
    Quote Originally Posted by sspine
    Hi, and welcome to the forum! You've made a great choice in taking a proactive roll in your pool and by comming here to get advice on how to do it, properly ! The 'plug' of acid method for lowering total alkalinity has been debunked by the operator of this site(Ben/ Pooldoc), go to the second thread in the "dealing with alkalinity and calcium" topic (it's stickied)' for the low down on how to really lower alkalinity with acid.
    As a general question of 'how long should I wait to retest aftere adding something'; the answer is, 1 turnover. A 'turnover' is the amount of time you need to run the pump to have the gallonage of your pool pass through the filter. There are some great folks who regularly post here that can tell you an ~ exact #, if they know the size of your pool, what pump and filter you have, and a few other details about your plumbing. (for a 'quick and dirty' # - about 4 hrs. with the pump running should give you a good idea of what the change has been )
    Thank you for the help last night. I am a newbie converting from Bioguard.
    16x36 ig vinyl liner (21,000 g?)
    Hayward sand filter
    Hayward 2.5 hp pump
    I had high TA & CYA so pumped and refilled, added .75 gallon Muratic in 2 doses last night. Current numbers (have added 4 gal Walmart Ultra in past 4 days.
    FC 0
    TC 0
    CC 0
    Ph 7.7
    TA 175ppm (was 320 before refill and aeration)
    CA 250ppm
    Cya 58ppm (was 95 before refill and aeration)
    I don't know whether to get the clorine going or need to get the TA down more first. We just retired and have been watching this board for sometime now. You are great teachers. I have already learned a lot.
    Indiana.
    Your TA is probably not a problem where it is. You need chlorine before things get out of hand. Keep an eye on the pH. The other stuff can be tweaked at your convenience.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
