Closed Thread
Results 1 to 8 of 8
Thread: Aerator with flagstone coping and tile
    GTakacs is offline Registered+ Thread Analyst GTakacs 0
    Default Aerator with flagstone coping and tile
    Could someone show me an example how an aerator head looks like with flagstone coping and waterline tile?
    I am thinking about adding an aerator head to my pool but I just don't know where it would fit and how it would look like.
    The builder is trying to charge $350 for 3 spray heads which I think is excessive considering all it takes is a jandy valve and a 3/4" run from the pump to the edge of the pool and a $5 aerator fitting.
    South Florida
    Default Re: Aerator with flagstone coping and tile
    Quote Originally Posted by GTakacs
    You forgot PVC line to the aerators, PVC fittings to put it all together, and .... labor.
    Zina
    Pool-Design . net
    The project if fairly simple if the pool deck and tile have not been installed but if you are retrofitting its more complex. Take a look at these web sites for ideas.
    http://www-1.pentairwater.com/jwcs/w...egory_rn=21353
    www.watercrystalfountains.com
    www.standardbronzeco.com
    Thanks so much, I really like the watercrystal stuff, all I need to do now is source it from someone and plumb it.
    I don't even have a hole in the ground yet so I don't think it's too late to do anything.
    OK, I sourced the really nice water crystal crown jets and the flush mount foam jet at a local pool supply company.
    They're a bit too rich for my blood at $240 and $230 a piece price. It would be nice to have them but this is definetely something I'll have to sleep on.
    Pentair also makes a deck jet that is less on the walet
    http://www.pentairpool.com/misc/pdfs/drains/DeckJet.pdf
Closed Thread
