Thread: Setting up a pool soon and have questions
    Default Re: Setting up a pool soon and have questions
    None of your questions are ones I can answer specifically, but I can make some suggestions in sorting among the answers.
    1. Use the methods your pool mfg will warrant, if you can determine that.
    2. Ask the seller / mfg for info about construction methods.
    3. You can certainly dish the bottom a little -- probably even a foot -- IF you grade the slope evenly from the edges. Do NOT start the slope right at the edge of the bottom -- your walls and posts need something stable to rest on.
    Keep in mind that almost always 'listed' pool depths are 'flood depths' and only correspond to the working or normal depth on an IG pool with a rim flow gutter. Most other pools (like yours) will have an ACTUAL depth that is 6" to 8" less than the listed depth.
    Ben / PoolDoc
    Steve, unfortunately I also cannot answer your questions, but hopefully somebody will see your post and be able to. I just wanted to say hi and welcome to the forum. We are glad you found us and hope that you enjoy participating with us!
    Apr 2011
    Thanks for the reply and welcome.. I think I may have this figured out, but am still wondering about using a non expandable liner.. all the expandable ones I have found ar not very good looking. I only intend to go about 6 inches deeper. Hopefully i will be able to get away with the standard overlap liner
