I suspect you're right on the money there, and that would explain both the foam and the residual high CC. Scoop as much out as you can, and keep the chlorine levels up, and it will clear. Sometimes the residual of other chemical processes can create a HUGE chlorine demand, but if you can stay the course, it will be much easier to maintain than it was to clear up!
