Thread: Pump Size?
    Apr 2011
    Northeast
    Default Pump Size?
    I have a 16 x 32 inground pool starting at 3.5 ft and ending at 8ft. I need to change my pump and filter which is currently a hayward 1HP Super Pump and Hayward 244T Sand. The problem I have now is that when I replaced the liner 3 additional return lines were installed giving the pool 5 returns and 1 skimmer, all 1 1/2 plumbing and all individuall run. With my current pump, I am getting very low flow if any flow to the far returns should I upgrade pump size to 1 1/2 HP?
    Honesdale PA
    Default Re: Pump Size?
    Welcome to the forum. You have about the same size pool as I and the exact same pump and filter. However, 5 returns? Just my gut feel tells me upping the pump size won't affect the flow at the far returns that much. With that size plumbing I think I would try and restrict the flow to the closer returns to try and equalize the flow before going to a higher volume pump. I also suspect the single skimmer will be the choke point in the system.
    Poconos is on target -- there's no need to up the flow, just because you've got a better set of lines. In fact, since you apparently still have only one suction return (your skimmer) trying to increase the flow could cause problems. A 1 HP pump is PLENTY to connect to a single skimmer!
    PoolDoc
  1. Pump Size
    By poolpup in forum Pool Equipment & Operations
    Last Post: 09-04-2006, 03:15 PM
  2. Pump Size
    By poolpup in forum In-Ground Pool Construction and Repair
    Last Post: 08-20-2006, 11:10 AM
  3. Need New Pump What size HP?
    By Joe44 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-31-2006, 10:07 PM
  4. Pump size
    By BigSplash in forum In-Ground Pool Construction and Repair
    Last Post: 05-13-2006, 02:18 PM
  5. Pump size
    By ssweaser in forum Above-Ground Pool Construction & Repair
    Last Post: 05-12-2006, 07:57 AM
