Thread: Aalkalinity question
    Default Re: linux thread--alkalinity question
    Unless you have concrete pool, low CH isn't important to you. High CH might be, especially if you are using cal hypo to chlorinate or have a heater.
    I wouldn't worry too much about the alkalinity yet. Get your pool running, the pH adjusted, and an adequate stabilizer level, first. Once all that's done, you can look at alkalinity.
    Ben
    Apr 2011
    Augusta, Ga
    Thanks Ben. Actually, my CH was dropping as well and I raised it. I'm more concerned with the Alkalinity, mainly curious if leaves, pine needles, etc can lower the AK.
    If both TA and CH were dropping, then it sounds like you might have a leak, assuming your fill water is lower in CH and TA than your pool and that you have auto-fill. Either that or you've got rain overflow diluting the water.
    Leaves can have tannins that can be acidic which mostly lower pH and somewhat lower TA, but not by as much as you are seeing. I'll bet you are using test strips as those are notorious for inconsistent and incorrect results. Get yourself a good test kit, the Taylor K-2006.
    Apr 2011
    virginia
    I grew up in GA, and never saw large quantities of acid rain- but plenty of tannins! Oak, cypress, sycamore, etc...
    Around Atlanta may have worse acid rain, but the more suburban and rural areas aren't significant!
    Apr 2011
    Augusta, Ga
    No, I have a nice taylor kit I got from Leslie's that measures Cl, pH, TA, CH and CYA. Cost about $50 and does a nice job, so I don't think measurement is the problem. I think it was the storms that hit us in the Augusta area in late March and dumped lots of pine pollen and leaves in the pool. It seems to be stabilized now.
