Results 1 to 10 of 23
Thread: Cloudy Pool
    Jun 2010
    Mississippi
    Default Cloudy Pool
    I tested my pool everything looks good but only thing is I can't get pool to clear up. It is a cloudy blue. I have a sand filter and using Bleach NO shock or CHLORINE... The sand in filter is 2 years old.. When I vac. pool I set to waste. It is a 33' above ground app 28,000 gal. I have been dealing with a cloudy pool since the first of March.. I have my own Taylor test kit and all levels are in. Thanks for looking and the help.
    33'x33' round 28K gal AG vinyl pool; skimmer BBB; Sandollar 60 200lb sand sand filter; Pentair 1.5 pump; hrs; Taylor; well; summer: none; winter: none; ; PF:4.3
    Default Re: Cloudy Pool
    Hello, and welcome to the forum!!
    We'll be glad to try to help, but we'd just be guessing without some more information..
    Could you please post numbers for FC, TC or CC, pH, alk, CH, and CYA? Also, any other chemicals you might have added to the pool?
    Thanks...
    Jun 2010
    Mississippi
    Just curious about my post. Why it is not there
    Jun 2010
    Mississippi
    TC - 4.0
    pH - 7.4
    alk - 100
    CH 40
    CYA 40
    No other chemicals
    Sand filter
    Have you recently killed off an algae bloom? If so, then you probably just haven't given the filter enough time to clear the dead algae out of the water. Do you see anything shooting back into the pool from the returns?
    Is the problem new, or has it been that way for awhile? Do you see sand in the bottom of the pool?
    What size filter and pump do you have?
    Quote Originally Posted by Dirtboy6 View Post
    New users' posts go into a queue once they're made, and they stay there until Ben or one of us 4 mods gets a chance to take a look at it and approve it before it goes onto the forum. Between the 5 of us, we're on the forum frequently all day (and sometimes during the night) so it shouldn't be long, once you've made a post ,before you see it on the forum.
    Jun 2010
    Mississippi
    FC - 5
    TC - 5
    pH - 7.4
    alk - 100
    CH - 40
    CYA - 40
    No other than bleach.. At this time I can't see the bottom due too the cloudy water. I believe I have dead algae that may be the cause. I run my pump 24/7 it is a sand dollar with a 1.5 hp pump.. This is the first year I have had this problem. The sand filter is in it's 3 year.. I backwash bout every 3 rd day. I also have a main drain. I run my manual vac. on waste and see a little green come out. I also have brushed the bottom of pool.
    I'm guessing you've got a system like this:
    http://www.intheswim.com/Pool-Equipm...-Ground-Pools/
    and probably an SD-80
    http://pentairpool.com/pool-owner/pr...filter-149.htm
    and a Dynamo pump
    http://pentairpool.com/pool-owner/pr...o-pumps-46.htm
    Is that right?
    If so, your pump is too big for your filter . . . even if it came that way from the factory. People are impressed with big pumps (Me big man; I gotta gazillion HP pump) but not with big filter (my filter is so-o-o big, it takes 10 minutes just to get to the other side). See what I mean?
    Anyhow, big pumps sell; big filters don't. On sand filters, when your filter is too big for the pump, everything is OK while everything is OK, but once you've got to do cleanup, watch out! The over sized pump pushes the dirt or dead algae all the way through the sand. Also, when you backwash an over sized pump tends to wash sand out of the filter, which then lets even MORE dirt through.
    First thing: check your filter to make sure it's full of sand.
    Second: do something to restrict the flow through your filter. At a lower flow rate the sand can begin to filter out the algae.
    Quick and dirty test to see if my guess about your system is right? Buy a small bag of DE, and dump some into the skimmer. Then run around to wherever the water returns to the pool fastest. Wait 5 minutes. If you see white powder blow back into the pool, you've got filter problems like I've described.
    PoolDoc
  1. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  2. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 06:55 PM
  3. Cloudy Pool
    By Rookie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2010, 03:19 PM
  4. Cloudy Pool
    By dustybecca in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2007, 02:35 PM
