Re: Air in lines
What's the clear lens? If you're referring to the sight glass on the valve assembly then you have a problem. Also, need more filter details. Sounds like a top mount valve assembly. The two screws sound like they are on a clamp ring that pulls the valve assembly onto the filter housing. Not unusual for it to leak after the Winter. Just tighten the screws equally until the leak stops. Use some judgement here. Don't overtighten to the point that you may snap the clamp ring. I would advise shutting the pump off before tightening the clamp ring. You don't want to do this under pressure for safety reasons.
