Your combined chlorine reading is the key issue. You need to get it below 0.5 by shocking the pool.
Thanks, I'll take another reading tonight and then shock again.Originally Posted by JohnT
So, is that getting rid of the CC.. ie, is it getting filtered out somehow.. or does it turn into something else..?
It's pretty fascinating reading some of these posts.. ie, algae eating and pooping stuff.. (I hate when that happens).. and so I'm assuming that I also have a lot of dead algae.. and what is making it cloudy..? dead algae.? I know that's a broad question with many possibilities.. although is it something obvious in this case..?
First, I think your CC level of 6 is suspect. I would definitely test it again.
Secondly, you should get your FC level higher than 2.5, say around 10 ppm, and hold it there for a couple of days (CC is the "poop" you mentioned previously, or also known as used up FC. Shocking will inturn get rid of it.). This will require shocking and I'd use plain ultra bleach. I'm not sure how many gallons it will take since you didn't say how many gallons your pool is. You will have to add it several times a day, brushing and vacuuming to waste at least once a day. You could also use Cal Hypo to shock but since you didn't post CH (calcium hardness) numbers it is not at the top of my recommendations since your CH level may be high from last years shocking.
Since your CYA is 0, I see nothing wrong with using the "pucks" after you get rid of the algae but keep a close eye on PH as they tend to lower it rather quickly. Don't use them now and empty your feader if you have one while using the bleach. You should also post your ALK numbers as well. Hold off putting any other chemicals/clarifiers in the water until this problem is resolved.
Thanks for your advise David.
I did shock it with a couple of bags last night after taking my readings.. so I'd imagine that my FC has gone up considerably. I'll check both again when I get off work.
I was curious about my ALK and so I think it tested around 120 or thereabouts. I'm not sure of the CH as I have not yet tested for that.
I'm working until 7PM today and also tomorrow, so I may not be able to do much for now, but after that I'll have a few days to focus all my attention on it. I'm running the pump 24/7 in the mean time.
Thanks again, it's much appreciated.
ALK seems fine and unless your CH is way high (450 or above?) it should also be fine. The main point is that you should keep your FC up until the algae is gone. You can go ahead and get started by shocking again tonight if needed. Any idea how many gallons you have?
being a 16x32 with a 3' shallow end and an 8' deep end, I'd guestimate ~24000 gallons.. does that sound close..? I'm pretty sure it's somewhere in that ballpark.
I'll test my CH tonight as well and then post it.
Does it being too high result in cloudiness etc.. ?
