Thread: Can I keep my pool closed this year?
    timmie is offline Registered+ Thread Analyst timmie 0
    manitoba, canada
    Default Can I keep my pool closed this year?
    Hi, I am not sure if I want to close my pool, but I would not like to use it this year. I have a very heavy winter cover on it that lets no sunlight in. I had the cover custom made.
    Can I leave my pool for the summer without opening it?? Do I need to drain all of the water off of the cover??
    I live in Winnipeg Manitoba, Canada and dont even know what to do in order to fill my pool in so its not used anymore. Can anyone answer my questions for me??
    Timmie
    Honesdale PA
    Default Re: Can I keep my pool closed this year?
    I see there are no suggestions for a few days so I'll take a crack at it. I assume your equipment is winterized, pipes drained and plugged etc and that you want to leave it that way for the summer. If you want to keep the water from turning pea green then I would try adding bleach to get your chlorine level up and the rest of the chemistry right, and use a small sump pump to do some circulating. Stick the pump in the shallow end, on a step maybe, and discharge in the deep end. I am assuming you have a deep end and suggest the pump in the shallow to reduce the chance of water leaking into the pump from the higher pressure of being in the deep end. If no deep end then just circulate one end to the other. Since you have a good solid cover then there should be no dirt issue. I would also drain water off the cover to keep it from sagging. I think there are small pumps specifically for draining covers but not sure.
    Hope this helps.
    Any other ideas out there?
