Intex 18'x48" empty and currently disassembled and stored in the basement.Originally Posted by Watermom
Test your fill water and then somebody here can advise you as to what all you would need to do when you set up and fill the pool.
What do I test it for. I assume ph and alk. anything else. The water supply is a well with a water softner that I will have on cleaning cycle for at least two weeks prior to fill.Originally Posted by Watermom
Maybe some metals. I'm going to let someone else who is more familiar with using well water advise you on filling from a well. Good luck with getting it going.
