Thread: 26k gal AGP adding salt
    Apr 2011
    virginia
    Default 26k gal AGP adding salt
    My pool is still covered, but hooked up pump yesterday in preparation to open (next weekend maybe- still a little cold!).
    So one thing I decided to do this year, is add salt; I may get a SWCG soon, but even if not still wanted the higher TDS and softening affects of salt.
    Added app. 500 lb yesterday, by adding to skimmer while running pump- took a couple hours to add a pound at a time and let dissolve...
    Before adding, I tested ph at 7.6; and I assumed 0 Cl as has been closed all winter... this was done with standard 2 way test, as didn't want to waste the reagents in my new Taylor kit until I was close on chemistry.
    after adding the salt, also added 2.8 gal 6% bleach...
    Then, tested Cl and ph- Cl was off the chart (>5ppm) and ph was 8.0!
    I know this much bleach shouldn't have this affect, should have been about 3ppm Cl... and little affect on ph...
    Does adding salt affect the ph? do I need to counter with acid- or wait until I get the cover off and full circulation for a few days before balancing?
    May 2010
    Route 100
    Default Re: 26k gal AGP adding salt
    Adding 2.8gals of 6% bleach would raise FC by 6-7ppm in a 26k Gal pool, depnding on how strong the 6% bleach actually was (can be as high as 8%).
    Typically, 1 gal of 6% Bleach will raise FC by 6ppm in a 10k gal pool.
    Moderator at another pool maintenace forum
    24' Round AGP, SWG, 0.5hp pump, 250lb sand filter,
    Apr 2011
    virginia
    pool still covered, but actually tested all parameters today.
    Since the previous post, I added 4 cups MA, over 3 days.
    FC 10
    CC 0
    TA 40
    CH 150
    CYA 40-50
    pH 7.4
    my guess now is that there was still some Cl in the pool, and the additional just pushed it higher- teach me to assume!
    The pH I guess was the result of circulating the water over several days...
    Since the Cl is holding up, and no CC, I think I'm in good shape for removing the cover and starting the season!
    Probably taking off cover this weekend, and then retest in a few days- hoping my temp holds, is at 68F now!
