Results 1 to 10 of 11
Thread: StaRite PLD series filter pre-coat
    Default Re: Just wanted to be able to search the forums...
    Actually, you can search.
    The link, above in WaterMom's post, and below my sig that says "Google Search PoolSolutions and 30,000+ PoolForum posts" takes you to a Google search of all of PoolSolutions and the PoolForum, minus posts in the last few days. It actually is a much better general search, than the built in search function.
    It doesn't do as well with specialized things, like search for all the posts by a particular user or on a certain date . . . but that's of more use to moderators than regular users.
    Ben
    May 2011
    Hmm, I don't see a link in her post, nor do I see your signature. Is that a limitation of being a trial user?
    I can't click on your name to view your profile either.
    May 2011
    Post Re: Just wanted to be able to search the forums...
    Oh, think I found it by doing a regular Google search with what you said, lol.
    It didn't come up with any results from my model number of DE filter though.
    This is the part of my manual I'm talking about. Maybe I should just see if you guys have seen something like his or get your opinion. Has anyone seen something similar to this? Where a smaller filter uses more DE than the bigger one?
    http://echo7.x10hosting.com/images/filter.jpg
    On this page:
    http://www.pentairpool.com/pool-pro/...series-169.htm
    I found this note:
    "3: PLD50 requires more D.E. than the PLD70 because of precoat design and flow characteristics!"
    I think that answers your question. BTW, thanks for the feedback on the signatures. I discovered that when I upgraded vBulletin version, the signature visibility of new members got turned off. It's going to take me awhile to fix that, but you should be able to see my signature now.
    Ben
    May 2011
    Awesome, yes I can see stuff now. And thanks for the answer too!
    Also just a note, when I was searching (yesterday as a trial user) from the search page you suggested, I had to log out in order to see any of the pages from the search results. While logged in it said I didn't have permission, lol.
    I saw on some thread that you said something about the System 3 from STA-RITE was crap, but I think you may have been talking about the cartridge filter instead of DE/Sand versions. The System 3 is what I have and I definitely see a small amount of stuff coming back into the pool through my filter when vacuuming (I even suspect DE coming out too from the type of dirt deposits I see on the floor a few days after cleaning).
    But first I need to more closely inspect my filter for issues and see if my pump is too big after looking through some other threads on the topic.
    May 2011
    Think I found my Culprit!
    Going to be ordering a new filter but I want to make sure of something real quick. Look at the filter online, it talks about a System 2 and mines a System 3. However, number that's in my manual matches that of the filter. Think I'll be alright?
    Order from a supplier using your FILTER model number; let them find the matching part; note the name of the order taker, and specifically ask THEM to find the part that goes with that filter.
    Ben
    May 2011
    Yeah, everything is matching so far, somewhat. My manual says 27002-0036S for the filter cartridge. This site has that same number and references the model number of my DE filter too. But I'll probably call to make sure because the system 2 and system 3 difference.
    http://www.poolsupplyworld.com/pools...7002-0036S.htm
    The cartridge/filter itself however, reads these 4 numbers in this order on top. Which doesn't make any sense to me. :/
    27002-0036
    27002-0030
    27002-0100
    27002-0150
