Results 1 to 9 of 9
Thread: 1.5hp pump with 1.5'' pipe?
    mas985's Avatar
    Pleasanton, CA
    Default Re: 1.5hp pump with 1.5'' pipe?
    Quote Originally Posted by lowtown90 View Post
    The pump was sucking water, but it wouldn't fill up the basket to the lid
    What is the filter PSI?
    If it is low, then there is probably a blockage in the suction line somewhere.
    If it is high, then the return side might be blocked somewhere and could be the filter.
    Either situation can lower flow rates such that the pump cannot expel the air in the pump basket. However, a suction side blockage will also tend to draw in air from the pump basket lid and other places.
    Mark
    Mantua, NJ
    Does the filter have a recirculate position? Bypass the filter to see if the pump primes.
    Joe
  1. Pump plumbing - Straight Pipe Important???
    By jaimslaw in forum Pool Equipment & Operations
    Last Post: 05-22-2011, 10:18 AM
  2. Pump Basket Debris Draining back into pipe
    By mjlepak in forum Pool Equipment & Operations
    Last Post: 06-02-2008, 09:21 PM
  3. Hard Pipe my pump and solar heater
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 05-22-2008, 07:14 PM
  4. My pump housing has iron pipe in the inlet/outlet
    By sailork in forum Pool Equipment & Operations
    Last Post: 06-10-2007, 02:27 PM
  5. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
