Results 11 to 20 of 21
Thread: Pool Test Kits
    Default Re: Pool Test Kits
    Yeah, I don't think Chem_geek was really arguing that the 0.2 FC resolution was the key point; it was just a topical fact.
    But he and I both have a tendency, when we post, to do an information dump of what we know on a topic, without running the "what information is relevant here?" filter as much as we should. Sometimes, that's because we don't know for sure what the OP needs to know, but sometimes it's just a matter of "if we know it, we say it".
    Ben
    Glenn,
    I use strips, have excellent color perception (unusual for a male but even my wife acknowledges it) so that's not a problem, but I don't rely on them. They are the canary in the coal mine to me--early warning of a problem. That's because I cannot tell if my pH is 7, 7.2, 7.6 or 7.8 using strips. Also, strips max out on FC at 10ppm. If you need to shock to 12, 15, 20 or 25ppm, they are useless. For CYA, they are inevitably wrong, and the TC tab on the strip usually reads lower than the FC, which isn't possible.
    With FAS/DPD you CAN read changes in FC or CC down to .2, but rarely will you ever. Most of us ALWAYS use the .5 scale. The ONLY time I have ever found the .2 scale useful is if I see a CC of .5 or less I can't seem to get rid of. Then I'll measure at the .2 scale and, inevitably, the CC reading is .2 or less, which IS trivial. But if it's higher than .2, but still lower than .5, I'll want to shock the pool before it becomes a problem.
    There is a way to use OTO testing to read higher than 3 or 5ppm, which works (search for the CarlD Shot Glass Method, or CarlD Patented Shot Glass Method ) by diluting with distilled water, but accuracy drops with each level of dilution.
    Yes, I wasn't recommending using a 25 ml sample with 0.2 ppm precision and accuracy, but rather that you COULD be that accurate if you wanted to and that it says something about the quality of the test. Most people use a 10 ml sample for 0.5 ppm precision and accuracy which is fine in most circumstances. For my own pool where I find the 0.2 ppm resolution useful is in two situations: 1) when I want a better handle on the Combined Chlorine (CC) level which is always very low in my pool (i.e. I want to know more than just <= 0.5 ppm; I want to know if it's <= 0.2 ppm) and 2) when doing an overnight chlorine loss test since such losses are also low or even when doing a daytime loss test. These latter loss tests are useful for figuring out average chlorine demand to the point where I can even tell when my wife has peed in the pool (see this thread, for example).
    Richard,
    You've just re-defined...TMI!
    Actually, I need to write a page about pool peeing and pool pee-ers. It's more common than you think and can have severe effects on water chemistry.
    FYI, 95+% of USS swimmers have developed the habit of peeing in pools -- practices are too long for any other option.
    Ben
  6. #16
    Not in my pool! I don't allow them to do that or swim in my toilets either!
    My Father had a sign: "This is our OOL. Notice there is no 'P' in it!"
    pratzert is offline Lifetime Member Thread Analyst pratzert 0
    Ben,
    Do you plan to sell your tweaked test kits again or are you advising everyone to use the k2006 ?
    How about refills of specific agents ?
    Thanks, Tim
  8. #18
    For the time being, there are several places online that you can get the reagents, whether it's Taylor's or Ben's kit. You can get them from the Taylor site, but I find spspoolspas.com has some of the most competitive prices. Some people have ordered from them and not been satisfied with their service, but I've never had a problem with them. Others use amato industries. If you need the crosslink between Ben's reagents and Taylor's, let me know, I think I still have it bookmarked.
    Thanks for the info Janet.
    I posed the question as I know that Ben had added a couple of items he felt were pretty much manditory for a really good kit. I can't recall exactly what those items were. I think one was may have been the stabilizer test chemical.
    If I can figure out what Ben had added to his kits, I can order them individually.
    So if you can find those links, that would certainly help.
    Thanks again for the info.
    Tim
  10. #20
  1. HTH Test Kits
    By Barry J in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2013, 02:06 PM
  2. re: Test Kits
    By Sumo1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 12-11-2006, 01:38 PM
  3. Ben's test kits
    By DONNIE in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 04:21 PM
  4. test kits
    By boscogabby in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 06:52 PM
